DIFF LOCK
Old May 8, 2007 | 09:06 AM
booboobear's Avatar
Default DIFF LOCK
can I put a diff lock in a 02 400i manual, and if I can, is it easy
Old May 8, 2007 | 10:07 PM
buckaroo50's Avatar
Default DIFF LOCK
Takes two people if you live in Winsted - lol
I think you can, you will need the differential (make sure you have 36 and 10 teeth for the ring and pinion) and actuator with the drive shaft, and the lever for your handlbars. Not sure about your axles you would have to cross reference them to see.
Contact this guy:
PJ Wanderscheid
Internet Sales Manager
38585 County Rd 186
Sauk Centre, MN 56378
Ph: 320-351-4481
Fax: 320-352-6372
E-mail: countrycat@wisper-wireless.com
They carry new and sometimes used parts. New you are probably looking at close to $600-$700, used maybe half of that. You probably would need one out of a 2004...
Old May 9, 2007 | 11:27 AM
mudslinginfool's Avatar
Does it in the Mud!
Default DIFF LOCK
i looked into a while ago for my 500. it would cost me(from the dealer) about $1400.00 if i remember correctly. included : cable,switch,new diff, it hink new axles(the splines are different) basiclly everything needed. if you get a price from the guy that buck sent you to, please let me know.
Old May 9, 2007 | 04:41 PM
booboobear's Avatar
Default DIFF LOCK
heres the deal, $300.00 for a used diff, $180.00 @2 shafts= $360.00, that is $660.00 total not counting cables. around $800.00 to do it, sell your diff with shafts for around $300.00 and you have a total of about $ 500.00 to do the diff lock. thanks buck for the info
Old May 9, 2007 | 07:22 PM
buckaroo50's Avatar
Default DIFF LOCK
You can get new Wild Boar axles out of Bangor Maine for $120 each - will save you $120 for 2. If you need the contact info let me know ok...
Need to find someone trading in a 04 and swap thing around... Never know for a $100 what some people will do...
Old May 13, 2007 | 10:21 AM
buckaroo50's Avatar
Default DIFF LOCK
Let me know when you get it, so I can scoff that at the same time as your brake pads.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
John Reed
Sep 9, 2015 03:46 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
panicmanic
Aug 25, 2015 09:10 AM
