Stripped out bolt hole in rear end Honda Recon
Old May 8, 2007 | 11:42 AM
Elimin8r's Avatar
Default Stripped out bolt hole in rear end Honda Recon
2004 Honda Recon ES.
Friends son took out drain plug for rear-end - dont ask me why.
When he put it back in it went in crooked and messed up the threads
in the rear end.
Could this be re-tapped?
Any other ideas.
I'm afraid of getting metal shards in the rear end if I have to drill it bigger and go with large bolt.
Old May 8, 2007 | 11:56 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
After you drill and tap it, you can just flush it with lots of oil to get out any shavings.
Old May 8, 2007 | 12:27 PM
Raptoryfn660r's Avatar
RIP Dear Friend
Another thing is to add grease on the tap and clean the tap several times as you cut the threads. The grease will hold the chips on the tap. Then as reconranger suggested flush.
Old May 8, 2007 | 01:23 PM
Elimin8r's Avatar
Thanks for the tips guys.
Is there a recommended gear oil for this ATV?
Old May 8, 2007 | 01:39 PM
RIP Dear Friend
Hypoid gear oil SAE 80W90
You can purchase 8 oz containers at your honda dealer.
I would have to look in the owners manuel for the amount needed but I am not near manuel at this time.
Old May 8, 2007 | 02:42 PM
Red Rider
Make sure it is "hypoid" GL5.
Countrygirl1976
Jul 13, 2015 10:08 AM
rcappie4
Jul 10, 2015 04:54 PM
MNatv89
Jul 7, 2015 11:36 AM
Coryco
Jul 6, 2015 07:30 PM
Rider252
Jul 6, 2015 03:37 PM
