Trailblazer 250 blown? HELP
Old May 11, 2007 | 01:37 AM
Gurney's Avatar
Default Trailblazer 250 blown? HELP
Ok so the good ol TB i belive blew up today...the compression came bac at 90-93...it still should fire no? I noticed that it ran fine at first then i stopped added some gas and the thing started smoking BAD thick white smoke when ever i was giving it gas...then i stopped shut it off tryed to start it again but it wouldnt turn over..acted like it was sezied but after a lil bit i tryed again and it turned over...so i pulled the head off just to get a good look at the piston and it appered fine...so i bolted the head back on and tryed to turn it over again..it started to turn but after maybe 5sec of turning it stopped and smoke was comeing off off something near the primary cluch HELP ME!!
Old May 11, 2007 | 07:18 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did the oil injection stop working and you seized it up. you'll have to pull the carb off as well as the exhaust manifold to see if the sides of the piston has score marks. also could be the crank bearing. either way 90 psi isnt really good
Old May 11, 2007 | 12:32 PM
Gurney's Avatar
its not seized...it turns over...and when i had the head off the jug appered smooth as well
Old May 11, 2007 | 01:41 PM
Gurney's Avatar
Ok so i just called my local shop...he said it sounded like kerosen insteda gas...and sence i did not fill the "gas" can u im gonna try draining the tank and putting fresh gas in it
Old May 11, 2007 | 07:13 PM
drlang's Avatar
You've got a blower on your trailblazer? LOL Piston Wiseco, $120.00. Bore, $40.00. Top end gasket set, $20.00.
Lots more power for a buck 80 not so bad. How long did the last bore job last?
Old May 11, 2007 | 08:18 PM
Gurney's Avatar
i belive it was stock bore
Old May 11, 2007 | 08:37 PM
drlang's Avatar
That's pretty good, my last rebuild on a 250 Polaris was $450.00. That included everything down to the crank bearings.
I dropped the engine off though, did the R&R myself. They are great little engines. Doc
Old May 11, 2007 | 09:44 PM
Gurney's Avatar
well ya see i wanna get it going good and sell and save for a z400 because my buddy has one and is sooo nice
Old May 12, 2007 | 07:27 PM
dirtsnow's Avatar
could be stuck rings on the piston &/or bad crank bearings & crank seals, but
ya make sure there is real gas in the tank!!!!
bmxatv10
Oct 14, 2022 06:23 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
jsmit116
Sep 18, 2015 10:34 PM
chewy78
Sep 8, 2015 10:37 AM
