HOW DO YOU CAM IT???
Old Dec 25, 2000 | 10:15 PM
jiz's Avatar
jiz
I READ ON A POST THAT YOU COULD MAKE YOUR 300EX FASTER IF YOU GO UP ON YOUR COMPRESSION AND CAM IT! HOW DO YOU DO THOSE? PLEASE HELP!!!!
Old Dec 26, 2000 | 11:04 AM
THEXOTIC1's Avatar
You will have to send it out to a race shop like Tc racing , 4 stroke tech, and others. probably looking at $500 or more for the work.
Old Dec 26, 2000 | 11:14 AM
Trxoutlawz's Avatar
Jiz...
You don't have to send your work to a shop if you are comfortable about opening your engine. Go to www.webcaminc.com for a cam. Lots of info there to help you decide which cam is best for your application.
You will need a new piston if you want to up the compression. You can get a hold of weisco or others depending on what you want. Do a little research..
I will suggest you go to your next oversize to clean things up.. Ask around and you will find a machine shop to do the boring for you after you get the piston.
Then all you need is a set of top end gaskets and someone to help you along if you are not comfortable about doing the work yourself.
Email me if you have any further questions and I will help you find any info you may need.
Later
Clutch
Http://www.Trxoutlawz.com
