05 Sportsman 500 Dead
Old May 12, 2007 | 11:17 PM
Polaris6's Avatar
Default 05 Sportsman 500 Dead
I have a 2005 Sportsman 500. I got on it today, turned the key, and absolutely nothing happened (no lights, no LED screen,... nothing). I thought maybe the battery was totally dead, so I hooked-up a battery charger for an hour, but still nothing when I turn the key (no lights, no LED screen,...). This seemed very strange to me because I just finished riding it 2 hours before this happened, and everything was just fine.
Does anyone have any suggestions on what may have went wrong? Is there a fuse somewhere that may have blown? Is this make and model notorious for suddenly going dead, and a certain part needs replaced?
I appreciate your comments and suggestions on how to fix it. I thought I would ask you guys and girls before I hauled it to the dealer.
Thank you
Old May 12, 2007 | 11:19 PM
trailbound's Avatar
Sounds like the surfire module/ECM. Where's caper when we need him. There was a recall with certain V.I.Ns. You should be able to check it out somewhere.
Old May 12, 2007 | 11:21 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
not sure, but if you follow the batterycables there might be a fuseable link in the line. make sure you have all good connections and no corrosion. make sure kill switch isnt on or messed up as well.
Old May 12, 2007 | 11:25 PM
trailbound's Avatar
Best way to troubleshoot the ECM/surefire module is to plug one in with the same part number, say from the same year machine with a friends help/parts.
Old May 13, 2007 | 08:50 AM
Polaris6's Avatar
Thank guys. I have a few questions:
1.) Does anyone know what (or where can I find out) the V.I.N. numbers were affected by this recall.
2.) Where is the surfire module/ECM?
3.) How much does the surfire module/ECM cost?
I'm thinking about replacing the surfire module/ECM (if it's not to much) and taking the chance that is what the problem is. I assume you can't return it once purchased?
Thank you
Old May 13, 2007 | 10:19 AM
rmkcac700's Avatar
all 05 500 SPs were in the range, ur dealer will test it for free, and the module is under the recall that is free replacemnt and labour allowance. It is most defiantly the surpower module...get it replaced soon, u should unhook the groundcable, they are known to short out inside the module and possibly catch fire
Old May 13, 2007 | 11:16 AM
miniexcavator's Avatar
are you sure your kill switch is in the on position?
Old May 13, 2007 | 11:44 AM
Polaris6's Avatar
Yes, I checked the kill swith, battery connections, recharged battery, iginition,... I simply have no power.
Thanks
Old May 13, 2007 | 11:51 AM
trailbound's Avatar
Good luck polaris6
Old May 14, 2007 | 05:53 PM
team orange peel's Avatar
I am new to this forum and have a question, my friend had a problem with his 06 500, i tok a look and his ecm and main harness were fried crisp. How common is this ?looks likepolaris has a problem and i've heard they wont fix them if they are out of warrenty . What do you regulars on this forumknow ? thanks gary
slowgsxr97
Mar 18, 2022 03:40 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Hondamx751
Aug 13, 2015 01:06 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
