Sport Quads Discussions on sport quads.
No Throttle Response?
Old May 13, 2007 | 03:17 PM
Whip's Avatar
Default No Throttle Response?
My 400EX had no throttle response a while back. no wheelies, burn outs, acceleration, did only about 25-30 mph. I had a clutch put in same thing, i bored out the piston, new piston, new clutch cable and it worked fine. Now it is doing the same thing. is it the piston again or is the whole thing junk please help me!
Old May 13, 2007 | 07:41 PM
KFX400JUMPIN's Avatar
well the problem is its a honda.
Old May 14, 2007 | 01:03 PM
TRX450Rrider's Avatar
It sounds to me like the problem is in the carb. When was the last time you drained and cleaned the float bowl. Also, have you done any recent airbox or exhaust mods? If you have, you need to re-jet.
If you ease into the throttle does it pick up speed? If you pin the throttle does it bog down and want to die? If the answer is yes to either of these, you problem is more than likely some dirt or something got into your gas tank and is clogging your jets.
Old May 21, 2007 | 08:38 AM
Whip's Avatar
Thanks TRX450Rrider. It was the carb. it is running great now.
2quiker
Mar 22, 2022 08:36 PM
Customer Service #1
May 15, 2020 08:46 AM
hueby
Nov 6, 2015 11:34 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
