repair my pipe
Old Dec 26, 2000 | 04:57 PM
250rrider's Avatar
does anybody know of a place that repairs pipes?
websites or phone numbers are needed
has anybody had experience with pipe repairing?
Old Dec 26, 2000 | 08:22 PM
motorman's Avatar
if you are trying to remove tha dinge,block off one end of the pipe with a good plug, attach a air hose to the other end, heat the dinged area with a large torch till it is red and the apply air pressure to the pipe. be careful not to blow out the plug and do not overheat the pipe. i have fixed pipes likes for years.
Old Dec 26, 2000 | 10:30 PM
250rrider's Avatar
what do you use for a plug?
about how much pressure do you use?
what do you do to plug the end with the air hose?
has this ever wrecked a pipe?
thank you
Old Dec 27, 2000 | 03:08 PM
motorman's Avatar
i use a rubber plug with a bolt throught it so i can expland the plug by tightening the bolt/nut. i use the same thing on the air hose end with a quick connect fitting. start out with 10 psi and increase it as you need to. if the pipe is creased this will not work.
Old Dec 30, 2000 | 12:41 AM
Air's Avatar
Air
Go to a parts store they have freeze plugs that are made out of rubber and expand.
Old Dec 30, 2000 | 04:56 AM
Bushbunny's Avatar
Hello You might want to have a look at a boat plug also...they are rubber and have a bolt through the middle also...they come in a few different sizes as well.....
BB
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
