Broken timing Chain - need help - fast
Old May 24, 2007 | 03:09 AM
MRDS650's Avatar
Canadian and Proud of it !!!
Default Broken timing Chain - need help - fast
Hey: Guys
Just put my motor back together tonight and installed in the bike. It turner over a couple of time and a clank noise came out. After that it seemed to turn over very fast. Took the valave cover off to find the timing chain had broke and piled up.
I am still not sure why the chain let go, only thing I can think of is it may have cockeyed when i put the head on last night. Everything seemed to go together all right.
Has anybody replaced a chain with the motor in the chassis, from what I can tell it should be possible.
Does anybody have a chain kicking around - I am heading to the dunes June 1st.
Old May 24, 2007 | 01:02 PM
bombrider04's Avatar
Did the chain actually break or do you just need a new chain tensioner?
Old May 24, 2007 | 02:03 PM
DuneMe's Avatar
Talk to Jeff Ross - He can get you a chain out of his inventory.
Nope, never had or heard of that occuring?
Old May 24, 2007 | 10:41 PM
MRDS650's Avatar
The chain did break. My local dealer here in BC said he could get me a new one over night. The dame thing is a $160 though, or well I guess I should just be happy I can get it in a day.
Spoke to Eric today and he has never seen I chain break either. I am just hoping I did not do any valve damage. (I just had the head ported and valves put in).
I am going to try and put the chain in while the motor is in the chassis. I think I should be able to lower it threw from the top and get it around the lower gear once I remove the side clutch cover.
Crossing my fingers and praying, I am suppose to head to St. A's next Friday
Old May 24, 2007 | 10:56 PM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
<div class="FTQUOTE"><begin quote>Originally posted by: MRDS650
I think I should be able to lower it threw from the top and get it around the lower gear once I remove the side clutch cover.</end quote></div>
I think you have to remove the clutch basket also.........
Old May 24, 2007 | 11:47 PM
MRDS650's Avatar
I have not had it apart yet. From the pictures I think you may be right.
I was really hoping that I could sneak it in there. Hopefully I will see a reason why it let go.
Old May 24, 2007 | 11:49 PM
MRDS650's Avatar
Big Daddy do you think I could do it by removing the timing gear??
Old May 25, 2007 | 06:30 AM
Big Daddy do you think I could do it by removing the timing gear??</end quote></div>
I'm not sure about the timing gear. The clutch basket looks to be the easier way to replace the chain from just looking at it.
Old May 25, 2007 | 07:00 AM
<div class="FTQUOTE"><begin quote>Originally posted by: Bigdaddy660R
I'm not sure about the timing gear. The clutch basket looks to be the easier way to replace the chain from just looking at it.</end quote></div>
Your in luck This is mine. I happen to be working on it at the moment.......
Old May 25, 2007 | 10:34 AM
MRDS650's Avatar
Thanks Big Daddy
It has been awhile since I had the clutch basket out. After i remove the 6 little bolts and the discs how does the basket come off ??. If I remember it should just slide off after that right ??
