2000 TB questions???????
Old May 24, 2007 | 03:25 AM
daddyed's Avatar
Default 2000 TB questions???????
I have been doing much work on my wifes 250 after it died at glamis a few months ago. I just finished rebuilding the top end and the carb, and have a few questios.
1- how do you know if the oil injector is working????
2- is it better to put a oil injector block off in, and pre mix(my 9 year old daughter rides a 2 stroke so I have to mix gas for her anyway)
3-Do you need to put any oil in the motor(bottom) or does the mix take care of this, and if so how do I check it????
Thanks so much for the help. I'm not to sure about two-strokes, mostly only dealt with four's
Old May 24, 2007 | 07:07 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if its a fresh rebuild, you should run a premix w/ the injection for the first tank of gas anyways to help lubicate. there is a priming the injection pump section in the manaul but since i sold our t.b i cant remeber but the proper way to do it. maybe some one knows the proper bleeding for this priming and cable adjustment.
Old May 24, 2007 | 02:50 PM
daddyed's Avatar
ok thanks if some one knows how to blead that, it would help a bunch. what about the oil in the bottom of the motor?
Njrider1230
Jul 29, 2023 05:16 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Aug 6, 2015 03:59 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
