Wheel bearing removal?
Old May 29, 2007 | 09:36 PM
Ripper29's Avatar
Default Wheel bearing removal?
Hey, I was just wondering how to remove the wheel bearing on a 1990 honda fourtrax 350 (front right, solid front axle). I have the brake "plate" assembly removed but it almost seems like i need a puller to remove the bearing.... Any help would be appreciated!
Old May 30, 2007 | 12:38 AM
rruser's Avatar
Are you sure its 1990? In most cases the bearings are pressed into the knuckle. You will have to remove the part with the bearing and press it out with a large vice or press. A hammer and large socket also works but you have to be careful not to jam the bearing up.
Ean
Dec 19, 2022 08:48 AM
joeyupton
Jul 14, 2015 11:51 AM
mudpig79
Jul 13, 2015 03:31 PM
clsharky
Jul 13, 2015 02:07 PM
