need help/info starter issues
Old Jul 13, 2015 | 01:08 AM
mudpig79's Avatar
Default need help/info starter issues
I have a 98 big bear 350 4x4 when the start button Is pushed the oil comes on and the starter justed spins anyideas please and thank
Old Jul 13, 2015 | 01:36 AM
greg74's Avatar
Sounds like you need a new starter. Are you able to start it by using the pull start?
Old Jul 13, 2015 | 09:25 AM
mudpig79's Avatar
Yes it will start with the pull start I pulled the starter and it kicks on with a set of jumper cables to the point I can bearly hold on to it
Old Jul 13, 2015 | 10:04 AM
bikedad3's Avatar
Might need a new starter but also check the gear that the starter engages inside the crankcase to see if there are broken teeth. That would make it do the same thing.
Old Jul 13, 2015 | 11:48 AM
Sounds like what one would do if the starter clutch is bad. Item#11.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old Jul 13, 2015 | 01:13 PM
greg74's Avatar
Wow, that's a pretty expensive part. I bet there are a lot of older quads that are pull-start only because of that.
Old Jul 13, 2015 | 02:01 PM
mudpig79's Avatar
If I look in the starter hole the is no gear that I can see
Old Jul 13, 2015 | 03:31 PM
bikedad3's Avatar
Should be able to see the top of a gear that the starter engages. If that gear is not there, than that's your issue and you'll need to get a new starter clutch flywheel.
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 27, 2015 03:15 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
