04 trail boss stall
Old May 30, 2007 | 07:41 AM
straightpipe's Avatar
Default 04 trail boss stall
Does anybody know if the trail boss thermistor will shut the machine down when it gets hot? It seems to happen when I ride for about an hour or so.
Old May 30, 2007 | 07:50 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like its vapor locking. make sure all the vent lines are clear and not pinched. as well as the gas tank. if you unscrew the gas cap does pressure exscape? there shouldnt be any pressure. just a thoguht.
Old May 30, 2007 | 08:25 AM
I did notice that when it stalls if I lift the pull starter handle there is vapor build up in the crank case. I tried the gas cap and checked the vent lines. They all looked good. What now?
Old May 30, 2007 | 09:36 AM
Old May 30, 2007 | 05:40 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
does that have check valves in the vent lines from the carb? make sure thier working right. should only pass air one way. when you say hot, you dont mean over heating do ya?
Old May 31, 2007 | 07:27 AM
It's not over heating. I'm not sure about the check valves. I'll look tonight. Thanks for your input.
Old Deer Hunter
Sep 2, 2015 01:39 AM
Anomers
Aug 16, 2015 11:06 AM
Backwoods_badass
Aug 1, 2015 10:25 PM
Gnuters
Jul 19, 2015 10:03 AM
