Recitifier Location
Old Jun 5, 2007 | 05:16 PM
H0nDo's Avatar
Default Recitifier Location
After removing my airbox I now need a new place to mount my recitifier. I found a place I think will work, above the rear shock, where the front of the rear fender is bolted down. I kept the rubber washers to mount it again and plan on just drilling new holes through the metal plate there. Has anyone mounted in this location, or where do ya'll usually put it?
Thanks in advance,
Seth
Old Jun 5, 2007 | 07:10 PM
dsmasterzach's Avatar
i put mine in the left hole on the subframe where a bolt holding the airbox used to be.
Old Jun 5, 2007 | 07:44 PM
Scatterbrain's Avatar
I drilled some holes under the rear plastic where the tool compartment is and mounted it there. The nuts that hold it on are inside the compartment if that helps the visual
Old Jun 5, 2007 | 10:36 PM
bombrider04's Avatar
You can also mount a bracket to hold the rectifier onto the suframe where the airbox hole is...I forget whose I saw like that, but someone on here had a bracket like that.
Old Jun 6, 2007 | 12:28 AM
FatHolly's Avatar
I use a piece of flat alum stock and some spacers under the battery which I have flat up under the seat. I have the rect and the starter relay mounted there.
EIF
Apr 20, 2017 07:15 PM
Oct 10, 2015 10:20 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
ScopeZ_
Sep 13, 2015 07:55 AM
