What could happen?
Old Dec 28, 2000 | 12:11 AM
warrior3443's Avatar
What can happen by runnin ur fourwheeler too lean? What kinda motor damage could it cause? i have always wondered.
Old Dec 28, 2000 | 12:52 AM
Air's Avatar
Air
It all depends on what kind of engine it is in.
A two-cycle will melt down. A four-cycle will suffer from overheating first then varying degrees of engine damage.
Air's Avatar
Air
Old Dec 28, 2000 | 10:49 PM
Zorro's Avatar
On 2 and 4 stroke, your engine will overheat. On a 2 stroke, the heat will affect the piston (which is gonna grow bigger, because of the heat), getting larger, it will rub more into the cylinder sidewalls, BTW, getting more heat...etc and will finally get blocked in the cylinder wall. Seizing in. That's what's gonna happen.
On a 4 stroke...I don't really know...it will probably keep on running, BUT you will damage your bearings (inside the engine)...you might also break the rod (BIG damage inside the engine).
Knowing this, you understand why most people run too rich...
Old Dec 29, 2000 | 12:20 AM
Will runnin too rich hurt the motor?
Old Dec 29, 2000 | 12:38 AM
H300F's Avatar
no
shimanok2
Jan 29, 2016 07:37 PM
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
Elkaholic
Sep 6, 2015 02:44 PM
