kazuma 110 wont start when hot
Old Jun 7, 2007 | 11:22 AM
s16's Avatar
s16
Default kazuma 110 wont start when hot
i have a falcon 110 it will run fine for about 15 minutes. then wont start and no spark at the plug.
coil or cdi
Old Jun 7, 2007 | 12:25 PM
buckaroo50's Avatar
I would try a new spark plug then a new Lead wire (the one that goes to the spark plug)
Check all grounds and battery connections.
Problem: Engine will not start or is hard to start (No spark)
Condition Remedy
1. Spark plug fouled 1. Clean - replace plug
2. Spark plug wet 2. Clean - dry plug
3. Magneto defective 3. Replace magneto
4. CDI unit defective 4. Replace CDI unit
5. Ignition coil defective 5. Replace ignition coil
6. High-tension lead open - shorted 6. Replace high tension lead
Engine stalls easily
Condition Remedy
1. Spark plug fouled 1. Clean plug
2. Magneto defective 2. Replace magneto
3. CDI unit defective 3. Replace CDI unit
4. Carburetor jets obstructed 4. Clean jets
5. Valve clearance out of adjustment 5. Adjust clearance
Problem: Idling or low speed impaired
Condition Remedy
1. Slow jet obstructed - loose 1. Clean - tighten jet
2. Slow jet outlet obstructed 2. Clean outlet
3. Low speed fuel screw setting incorrect 3. Adjust screw
4. Starter valve not fully closed 4. Adjust valve
5. Float height incorrect 5. Adjust float height
Problem: Spark absent or weak
Condition Remedy
1. Ignition coil defective 1. Replace ignition coil
2. Spark plug defective 2. Replace plug
5. Pick-up coil defective 5. Replace pick-up coil
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
merryman
Jun 27, 2015 03:31 AM
1000gade
May 27, 2015 12:37 PM
