Carb help
Old Dec 28, 2000 | 01:48 AM
HondaMan85's Avatar
Whats the difference that bigger carb makes? I've got a 99 honda 3004x4, with a high lifter monster performance kit, vampires, and liftkit. SO i'm still looking even more power. With the bigger carb, it doesn't do much good though if you can't get enough air to it right? or am i wrong? how does the bigger carb work or help you? Cause since i ride in deep water i'm not gonna vent my air box. please help me
Old Dec 28, 2000 | 02:19 AM
JRM's Avatar
JRM
A big carb makes a huge difference only if the rest of the system can handel it. Cam, head, pipe and airbox will all need to be modified to use a bigger carb. If you do all of that you will loose low end torque with the large carb. My advise would to bore and stroke your quad and get a uni filter along with a new free flowing pipe but use the stock carb for grunt power. I just installed a wiseco pistion and cam in a friends XR200R and it made a big difference without buying a new carb.
Old Dec 28, 2000 | 03:45 PM
HondaMan85's Avatar
My 300 already has a k and n filter, with outerwears. A supertrapp IDS2 with all 12 disks in, and a dynojet jet kit, and is jetted correctly. So if i got t larger carb, how would that help my engine performance for mud running? The mud i run in is really.......i mean really thick.
Old Dec 28, 2000 | 09:45 PM
letitsnow's Avatar
Don't waste your money on a bigger carb. Unless you run it completely wide open all the time, it's not worth the low end that you will lose.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
