22/23 to 20/21 tires- Clutch kit needed?
Old Jun 11, 2007 | 12:54 PM
Nick21's Avatar
Default 22/23 to 20/21 tires- Clutch kit needed?
I am thinking about going from stock 22" rear 23" front tires on my 2x4 400 Scrambler to 20" rear 21" front tires. Will I need a clutch kit to keep my R's in the right spot?
As I understand it, I am basically gearing down (going down on front sprocket or up on back). I'd actually like a little more low end "wheelie" power, and I am ok loosing a few MPH on the top, but will I need to adjust my clutching for this?
Any thougts on if this is a good or bad idea?
Old Jun 11, 2007 | 03:34 PM
conig's Avatar
no you don't might want to consider 20's all around, being 2x4 it won;t hurt anything.
Old Jun 11, 2007 | 04:36 PM
Nick21's Avatar
I guess I just assumed it would handle better with 21" fronts. Don't most true sport quads run 20/21?
Old Jun 14, 2007 | 01:01 PM
Nick21's Avatar
Bump....does anyone have experience with 20" tires?
Old Jun 14, 2007 | 06:37 PM
ftwflh's Avatar
You will loose all your ground clearance with that set up.If you just want easier wheelies tighten the preload on the rear shock and clutch it a little aggresive like a brown primary spring with wieghts and set the secondary at 2-2. you wont be able to hold the front end down but then you can adjust the preload to wher you like the way it does.
Old Jun 15, 2007 | 12:14 PM
Nick21's Avatar
I'm new to quads, but is losing an inch really losing all of your clearance? I ride with banshees and preds mostly, which I assume would still have less clearance.
Also, I know I can clutch for wheelies, but I was thinking shorter, more MX style tires would handle better. I ride track mostly, and I'd like to be able to spin the tires so I can whip it around easier...
Rocketx
Nov 16, 2020 07:25 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
alix
Jul 1, 2015 10:33 AM
FourWheelOverTwo
May 31, 2015 07:26 PM
