Gas Tank Shield Problems
Old Jun 17, 2007 | 10:01 AM
Smokin' Joe's Avatar
Default Gas Tank Shield Problems
I've got a problem with the shield on the right side of the gas tank. It's a big ugly plastic shield to protect the tank from stones,etc. from the right hand rear wheel.
The problem is that stuff like little stones and mud get all jammed up in there and I want to remove it to give a good cleaning. Has anyone got step by step instructions for removing the tank?? or a solution to keep crap from getting in there in the first place??
Old Jun 17, 2007 | 02:19 PM
CATSKINNER's Avatar
Smokin, I would leave the guard there because it protects the tank from heat and it is also what helps keep the tank mounted to the frame and protects it from damage from rocks and sticks hitting it while riding. I sealed the gap on mine with 100% black silicone before I rode it the first time. If I were you, I would pull the tank and make sure it is completey cleaned out and then clean the surface where the silicone will be with alcohol and then seal it. I have never pulled the tank so I can not help you with removal.
Good luck.
Old Jun 17, 2007 | 11:48 PM
buckaroo50's Avatar
First of all what year and model of ATV do you have?
Have you considered some spray foam like what they use for insulation. The stuff will stick to anything basically. Probably can get some from Home Depot.
REMOVING
1. Remove the seat.
2. Remove the rear rack and fenders
3. Disconnect the hose(s) from the fuel pump to
the carburetor(s).
4. Remove the cap screws securing the gas tank to
the frame.
5. Disconnect the fuel gauge connector; then
remove the gas tank.
Old Jun 18, 2007 | 04:04 PM
It's a 2005 and it's a 500 Automatic.
Old Jun 18, 2007 | 08:03 PM
gtdoctor's Avatar
I've noticed this problem also, but I just use a pressure washer and blast it in the gap between the shield and the tank. It takes a little while, but you can get everything out that way. It only seems to accumulate in there after some serious mudding, so I only end up doing it a couple times a year.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
