2002 500i 4x4
Old Jun 18, 2007 | 12:22 AM
Turkeyboy's Avatar
Default 2002 500i 4x4
a buddy of mine has a 2002 500i 4x4 and when it gets in a bind it will smoke blue smoke some but is full of oil checks it reguraly and runs find til u put it in a strain? any help is appreciated
Old Jun 18, 2007 | 12:52 AM
buckaroo50's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Turkeyboy
a buddy of mine has a 2002 500i 4x4 and when it gets in a bind it will smoke blue smoke some but is full of oil checks it reguraly and runs find til u put it in a strain? any help is appreciated</end quote></div>
Problem: Exhaust smoke dirty or heavy
Condition Remedy
1. Oil (in the engine) overfilled - contaminated 1. Drain excess oil - replace oil
2. Piston rings - cylinder worn 2. Replace - service rings - cylinder
3. Valve guides worn 3. Replace guides
4. Cylinder wall scored - scuffed 4. Replace - service cylinder
5. Valve stems worn 5. Replace valves
6. Stem seals defective 6. Replace seals
Old Jun 19, 2007 | 04:49 PM
swampyjunior's Avatar
Sounds to me like it is burning oil. As Buck already posted, there are a couple of ways for that to happen.
-Valve guides, stems, seals
-Worn piston rings
-Over filled the oil
The cheap things to try first ( I have been accused of being cheap = Frugal). Make sure when checking the oil level you are not screwing the dipstick in. Get a bottle of oil additive like mystery oil and add it to the oil. Make sure you use an appropriate amout and that it does not have the slippery additives that would cause your clutch to slip. I would also run a compression test dry and then squirt a little oil (fogging oil) into the cylinder and retry the compression test. Check the results with what your engine is supposed to have. I do now know what it is and my manual is in my shop so hopefully you have a service manual.
My other question is if you ride it a bunch under strain how much does the oil level go down and what color is the spark plug after the ride? If it is not burning any oil or very little I would say "ride -on". But you may also want to check your water level as it could have a blown head gasket and you can easily mistake the color of the smoke. Blue = oil and bluishwhite = coolant. I am pretty sure your 2002 500i is water cooled.
Hope this helps
SJ
Old Jun 19, 2007 | 07:08 PM
buckaroo50's Avatar
On the 500, I believe the compression is 70-85psi with WOT (wide open throttle)
Old Jun 24, 2007 | 11:39 AM
JohnO's Avatar
It could also be sucking oil into the intake under heavy throttle - perhaps a clogged crankcase ventilator valve. Might check the air filter box to see if oil is being pulled into there. From what I've seen in the past, bad rings usually blow smoke all the time, while worn valve guides will blow smoke only on startup.
The 500 is a very solid engine. My 02 500i is still going strong, no smoke no matter how I push it.
95wolv
Sep 27, 2024 12:00 PM
atvcollector
Sep 8, 2015 05:11 PM
chewy78
Sep 8, 2015 10:37 AM
byronman
Sep 6, 2015 06:34 PM
