sputtering thru mud/water
Old Jun 18, 2007 | 01:54 PM
nashwaak1's Avatar
Default sputtering thru mud/water
hey guys
i had this problem fall and thought i corrected the problem but it is still doing it.
when i go into water up to the floor boards my bike just about dies, it spits sputters and seems to miss but it does go through thankfully, it will run bad for the next 2-3 min the clear right up. it doesnt happen when i hit a puddle at high speeds, just when i'm in a small pond or mud hole. When i look into the air box i no water inside, except for the fact that when it spits and sputters it seems to be leaving a black build up on the inside of the air box. i sprayed all the wires under the rack area last year, changed the plug,sealed the plug with dielectric grease, changed the air filter. after doing that last fall it seemed to work better but the problem is back again .
any suggestions
99 500 sportsman
Old Jun 18, 2007 | 04:55 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
dumb question, but is any of the vent lines getting under water or crimped off? just a thought.
Old Jun 18, 2007 | 05:30 PM
nashwaak1's Avatar
ARE YOU TALKING THE CARB VENT LINES?
I'M GOING TO HAVE TO SPEND SOME QUALITY TIME WITH THE OLD GIRL AND SOME BEER AND GO OVER ALL VENT,WIRES ETC...
THANKS
Old Jun 19, 2007 | 09:40 AM
colt2245p's Avatar
mine will do the same things. what i have decided is that when you are moving slowly the steam from the water getting on hot engine parts exhaust/head goes up around the tank and into your snorkel when you go thru one fast the steam doesnt get up there.
Old Jun 19, 2007 | 01:11 PM
Hotdogmb's Avatar
Make sure your plug boot is all the way down till it clicks into place. Had the same problem and that's what it was.
Old Jun 26, 2007 | 08:47 AM
nashwaak1's Avatar
i found the problem, thought i'd share
i realized that the problem wasn't only when i was in deep mud or water but was happening under load, (towing a buddy)
i removed my spark plug cap from the wire and cut about a 1/4 inch off the wire and re-installed the cap making sure it was on tight. took it out for a test ride and it worked great, better than it has in a while.
gotta love the cheap easy fixes
thanks
ReconBayou
Oct 31, 2022 05:37 PM
ltrmc02
Aug 22, 2021 02:34 PM
Bernhard
Sep 25, 2015 12:45 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Hw00d
Sep 10, 2015 08:53 AM
