06 sportsman 500 rear driven clutch ?
Old Jun 19, 2007 | 02:13 PM
checko's Avatar
Default 06 sportsman 500 rear driven clutch ?
Does anyone know what the effects are when the spring has gone out in the rear driven clutch? Do they go out often? I replaced all 3 ramp buttons which were broken and now Low works fine but High isnt gaining speed like its suppose to. The bushings were fine and all the other parts look ok so i'm assuming its the spring. The spring wasnt broken or didnt look stressed but i dont know what it look like when they go out...
Old Jun 19, 2007 | 04:41 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
are you sure you preloaded the spring when you put it bacl together and put the spring in the right holes? if the spring breaks, you should be able to slide the clutch sheeves right back in forth w/out much restiance. just a thought.
Old Jun 19, 2007 | 05:01 PM
Hotdogmb's Avatar
EBS secondary clutches don't have holes in them. You may need to sevice your primary clutch, or check your alingnment.
Old Jun 19, 2007 | 05:34 PM
checko's Avatar
yea i most likley didnt preload the spring properly. does anyone know of a site with those instructions... or a online service manual?
Hotdogmb sorry i forgot to mention its a HO. non EBS
Old Jun 20, 2007 | 07:28 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
<div class="FTQUOTE"><begin quote>Originally posted by: Hotdogmb
EBS secondary clutches don't have holes in them. You may need to sevice your primary clutch, or check your alingnment.</end quote></div>
non ebs have the standard secondary clutches. when you put the clutch sheeve on you need to rotate it about a 1/3 of a turn so the buttons will go to the next side of the ramp on the helix. its kinda of hard to explain lol. make sure you feel a preload when your winding the spring. it doesnt ktake alot to do it. hope this helps.
txkevin
Sep 21, 2015 02:02 PM
coldnorthpol
Jul 14, 2015 11:22 PM
Larry S
Jul 4, 2015 12:54 PM
Shifts
Jul 3, 2015 07:59 AM
VRRRRT
Jun 27, 2015 09:38 AM
