Tire chains
Old Dec 28, 2000 | 08:33 PM
DaBoss's Avatar
I'm thinking of getting some tire chains for my Y2K TBoss. From other posts it looks like they work great. Does anyone know if they are a problem at higher speeds? Keep in mind that 'higher speeds' would be about 45 for me.
They have some v-bar chains at Northern for under $25.
Thanks
Old Dec 29, 2000 | 12:07 AM
Dazed's Avatar
I will sell you my chains Used very little put on the mudrunners and never looked back There is a few tricks when using chains also If you want to know them email me i will tell you. What size tires do u run?
Old Dec 29, 2000 | 11:00 AM
dand11's Avatar
I have put tire chains on my 325 2X4 mag for the last two winters and pushed show with great success. I always deflate the tires, put the chains on as tight as they will go then put about 6psi back in. I can't tell you about going 45mph because that machine won't hardley do that on a good summer day but 30 to 35 is no problem. Chains help a lot when pushing a blade full of snow but don't help squat in the deep stuff if you are just joy riding. Once you get high centered under your skid plate you are done.
Dan
Old Dec 29, 2000 | 01:46 PM
gbMichigan's Avatar
What is Northern's web site I also would like some chains for my Trail Boss 2000.
Old Dec 29, 2000 | 01:47 PM
gbMichigan's Avatar
... or is there a better site that has good prices on snow chains?
Old Dec 29, 2000 | 05:34 PM
DaBoss's Avatar
www.northerntool.com
They are clearancing the chains out, order quick.
Old Dec 29, 2000 | 10:47 PM
400L's Avatar
Tire chains are okay, but if you want to try a better setup, try bolt tires. A few of us old wintertime dirt bikers put 1/4 inch carriage bolts thru the rear tires and ice screws in the front (2 wheel drive). No problems with chains flapping, or wrapping around an axle. My tb250 with bolt tires will out climb my 400 4x4 with Dunlops in snow or on frozen ground. I haven't made a set for the 4x4 yet, but as soon as the stock tires wear down more, they will be fitted. This has worked better than mud or paddle tires in deep snow, as they tend to dig down too much. If you begin to spin, back off the throttle and gently reapply it. Once you sink down to where your on the frame, you're done. Time to get off and lift. Good luck. One other thing, hippo hands and an electric vest make those snow rides much nicer.
Old Dec 30, 2000 | 01:13 AM
gbMichigan's Avatar
What size do I need for my Trail Boss 2000?
Old Dec 30, 2000 | 12:16 PM
DaBoss's Avatar
gbMichigan, the rear stock tires are 22x11x10
Item #6410 at NorthernTool are the ones you want..
I'm kinda worried about having them come off at higher speeds, anyone know how well they hold?
Old Dec 30, 2000 | 12:32 PM
BLH's Avatar
BLH
So, please explain how exactly how to make these tires, I have an old set on rims sitting in the barn, it’d be great if I could get some use out of them. Thanks…
