2003 sportsman 700
welcome to the forum. if you mean to get the axle out of the rear end it pulls outw/ a snap. sometimes you have to get a bar behind it to help it if its been in there along time.
IF YOU DON'T HAVE THE AXLE PULLED YET ALL YOU HAVE TO DO IS PULL OUT THE WHOLE ASSEMBLY FROM THE REAR GEAR CASE. THERE IS A LITTLE CLIP IN THERE THAT HOLDS IT IN PLACE, JUST GIVE IT A FEW YANKS AND SHE'LL COME.
IF YOU ALREADY HAVE THE WHOLE ASSEMBLY REMOVED AND YOUR ASKING HOW TO REMOVE THE CV JOINT FROM THE AXLE YOU NEED A SPECIAL TOOL. BUT YOU CAN DO IT WITH 2 SCREW DRIVERS. THERE IS ANOTHER CLIP CONNECTING THE AXLE TO THE CV JOINT. CLEAR THE GREASE AWAY AND YOU'LL SEE IT. SPREAD THAT CLIP APART AND PULL THE AXLE OUT (IT'S EASIER WITH 2 PEOPLE)
<div class="FTQUOTE"><begin quote>Originally posted by: WV SWAMPTHING
IF YOU ALREADY HAVE THE WHOLE ASSEMBLY REMOVED AND YOUR ASKING HOW TO REMOVE THE CV JOINT FROM THE AXLE YOU NEED A SPECIAL TOOL. BUT YOU CAN DO IT WITH 2 SCREW DRIVERS. THERE IS ANOTHER CLIP CONNECTING THE AXLE TO THE CV JOINT. CLEAR THE GREASE AWAY AND YOU'LL SEE IT. SPREAD THAT CLIP APART AND PULL THE AXLE OUT (IT'S EASIER WITH 2 PEOPLE)</end quote></div>
if this is what your asking take a look at my pics. and you'll see the clip hes talking about.
sweaver
11
Aug 18, 2015 03:47 PM
bpegram84
Jul 22, 2015 08:15 AM
