NEED HELP ASAP!
Old Jun 21, 2007 | 02:23 PM
jofenloch's Avatar
Default NEED HELP ASAP!
Alright so i got stuck in mud up to the floor boards last weekend and ever since then my 99 magnum 500 has run like crap. There is grinding noise either coming from the brakes or the engine, it bogs out when i push the throttle more than 1/2, and will not go over 35mph. I have changed the fuel filter, spark plug and air filter and nothing seems to be working. If anyone has any advice let me know...thanks!!!
Old Jun 23, 2007 | 08:23 PM
slowpoker's Avatar
i have a new 05 700 twin and it did the same thing (without the grinding). the cure was the foam just above the air filter intake snorkel on the gas tank had slid down slightly and was restricting air flow. push your finger above the intake and push the foam up and see if that helps. good luck!!!
Old Jun 23, 2007 | 10:57 PM
Williebee's Avatar
If that doesn't do it , check to see if one of the shorkel's is loose or came loose when you got stuck in the mudhold ; if one of shorkel's came loose it could have gooten mud inside the belt/clutch housing causing the noise ! And if the air intake was loose mud could've gooten into the air box intake , best way to tell is remove the cover where the belt and clutch is and check it out ! willieebee
Old Jun 23, 2007 | 11:35 PM
ftwflh's Avatar
Clean the air filter and airbox.Then pull the clutch cover and check for belt wear,secondary clutch problems.Clean it good all over.
MUD IS NOT GOOD it breaks stuff and costs you $$$$$$$
slowgsxr97
Sep 8, 2015 07:33 PM
400H0
10
Aug 20, 2015 07:34 PM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
mitchxc700
Aug 10, 2015 09:26 PM
Daryl Devine
Technical and How-To Articles
Jun 8, 2015 08:59 AM
