Chain Adjustment
Old Jun 21, 2007 | 04:40 PM
ridered28's Avatar
Default Chain Adjustment
Hey guys I noticed my chain is stretching a little. Anyone know how to tighten the chain on an 05 400ex?
Old Jun 21, 2007 | 05:56 PM
bombrider04's Avatar
It is a simple procedure and welcome to the forums...When you look at the rear you will see on the swingarm that there are bolts holding the carrier tight (either 2 or 4 bolts not sure with the 400 how many there are) loosen up the bolts and that will allow you to turn the carrier...I usually take a screwdriver or there is a thing in my 450r kit that allows me to fit into the slots on the rear carrier...Put one of them through the holes on the rear sprocket and into the groove on the carrier and push the bike forward or back to loosen or tighten the chain...Make sure it is up to specs with play in the chain and clean and lube the chain if needed...If you need any help or clearing up let me know.
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
craacker
Sep 9, 2015 04:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
goosemasterkl
Aug 23, 2015 11:36 AM
