Fuel leak-new to this 2001 350 Rancher
Old Jun 22, 2007 | 07:20 PM
deric203's Avatar
Default Fuel leak-new to this 2001 350 Rancher
Just bought a 2001 Rancher. Has 49 hours on it. Everything looks and runs perfect.
A fuel line (looks like an overflow) near rear suspension is leaking.Drips right out of the line.
Changing oil, air filter, oil filter and fuel now. What other maintenance should I check. No maintenance history available.
Thanks for the help.
Old Jun 23, 2007 | 08:53 AM
quicksilver's Avatar
if you left the fuel valve turned on while trailering/hauling, i wouldnt worry about it, just a little fuel sloshing around in the carb.
if it still leaks when sitting in a garage, etc... you might have a bad float and/or float valve in the carburetor
check valve clearance as per a shop manual, l
Old Jun 23, 2007 | 10:26 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Probably the float in the carb is stuck open. Might be a little bit of grit, or it could need adjusting.
My Rancher did the same thing and I took it out and did a few big jumps and it cured the problem (probably racked the float up and down and dislodged some grit). Still, if I had a new (used) machine, I would clean the carb just so I knew what I was starting with....
Old Jun 23, 2007 | 02:52 PM
hondamantrx440ex's Avatar
Are you sure it is fuel? I have a 06 Rancher 350 and it has a breather hose comming up from the rear differential going up high by the shock. Our fuel overflow go down by the front shocks, that year might be different don't know!
Hunter100us
Oct 7, 2015 11:46 PM
bradco
Aug 21, 2015 08:11 PM
Aitch
Jul 21, 2015 09:40 PM
Scottma518
Jul 16, 2015 09:19 PM
maxjung
Jul 14, 2015 03:10 AM
