Miracle juice in an aerosol can .
You know the deal , rusty bolt that refuses to unscrew and if extra pressure applied it will surely twist off .
I have seen the ritual of *soaking it in miracle juice* and returming later to attempt to remove it . I can't recall ever having this ever work for me .
Has anyone found a *miracle juice * that actually does loosen rusted bolts on a regular basis ? Or have we all been duped into this seemingly universal ritual that rarely gives the results we were expecting .
The best thing I've found to use is transmission fluid. I've used it on everything that didn't want to budge. U-bolts on my truck, plow frame, exhaust hangers/clamps, I've even poured some into the cylinders on a V8 that sat outside for a few years in order to get the pistons out with out breakin' em. Tranny fluid works better than wd-40 or anything else of that nature. I use the cheap "tech 2000" from wal-mart, just so I don't waste the good stuff for my car.
Rick, you caught me outside the workshop; the can's not within my view and the name escapes my flawed memory, but: this stuff is a "catalyst" or something; uses chemical action to break up the corrosion binding rusty nuts, bolts, screws, etc. I'll check it out tomorrow and post the name--I've had considerable success with the concoction.
Diogenes
Diogenes
Trailbreaker your right about ZEP products they work like you would'nt believe.
I use the car wash/degreaser on my scrambler to get the grease off that the chain flings,I'm impressed.
I cant find it in stores though, the only way I can get it is through my company.
2000 SCRAMBLER 400 2X4
SCRAMDADDY400
SCRAMDADDY400
