Oil Change
Old Jun 25, 2007 | 01:05 AM
texdad's Avatar
Default Oil Change
I'm new to atvs and ran in to a surprise when attempting to change the oil. I found what I thought had to be the drain plug and removed it. Out came a long spring attached to a metal cylinder with holes in it. The one thing that did not come out was the oil. The dip stick shows that its full. Can I get some tips on what I need to be doing? I didn't see any other bolt on the bottom that looked like it would be a drain plug.
Thanks
Bryan
Old Jun 25, 2007 | 05:33 PM
MAS's Avatar
MAS
Default Oil Change
i,m not an expert but, on my sunl 125, there are 2 bolts on the bottom of the engine. one is at an angle (the oil pump bolt) and one is straight in (the oil drain bolt) the one that you loosened is the oil pump plug bolt. look around for the other one
Old Jun 26, 2007 | 07:45 PM
texdad's Avatar
Default Oil Change
Got it changed. Thanks for the reply
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
