Rancher problem
Old Jun 28, 2007 | 06:58 PM
quadcraz3d12's Avatar
Default Rancher problem
hey guys,I just took out my rancher today and forgot that the kill switch was on so it wouldnt start..about 5 seconds after trying to start the quad I noticed that the kill switch was in the non running engine position(idk) then i turned it to the running position and thought it would start right up...then when I tried to start it again it made a loud boom noise(it sounded like a gun shot) which scared the living **** outta me...idk what happend but when I tryed to start it again it ran fine..anyway if anyone knows exactly why this happend please post
Old Jun 28, 2007 | 08:57 PM
mykool61679's Avatar
maybe carbon build up?
Old Jun 29, 2007 | 01:15 AM
Gimpster's Avatar
hehehe, you fouled a spark plug and when it did fire the unburnt gasses in the engine and pipe lit off
that's kinda funny.... left some bacon strips in the shorts huh...
----- Gimpster -----
Old Jun 29, 2007 | 09:27 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
This one is easy. While you were cranking it with the kill switch on, you forced a bunch of unburned fuel into the exhaust system. When you finally got it started, the first hot exhaust pulse ignited all that unburned fuel....bang....
Hardly a "problem" like your title implies (I was expecting something horific). Probably didn't do any real damage!
Old Jun 29, 2007 | 11:25 AM
gillygutty's Avatar
Ok Folks, I need some help.
I have a 98 450ES. I went to get on it the other day and nothing happens with the Electric Shift buttons. When I hit the buttons, you get no sound, no shift, no nothing.
Here is what I have done so far.
I have taken the switch apart, it looks good. I do however only have a little over 5 volts going into the switch and then 5 volts coming out of the switch. This tells me "I THINK" that my switch is operating perfectly, but I have heard it takes 11 Volts to change gears (Correct me if I am wrong) then somewhere between the battery and the switch I am going from 12 Volts to 5 volts and therefore I guess I am getting nothing from the switch due to lack of power.
Please tell me if I am wrong, and let me know if you have any suggestions or thoughts.
P.S. With the manual shift attachment, the bike does shift gears fine, crank up fine, and run fine. The Electric Shift just want change the gears.
Old Jul 4, 2007 | 02:49 PM
haha yea not really a problem but it scared me enough to think it was a problem
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
hondarider1234
Jul 21, 2015 11:53 PM
Scottma518
Jul 16, 2015 09:19 PM
RedRancher
Jul 10, 2015 06:36 PM
Scottma518
Jul 10, 2015 12:42 AM
