Honda Carb info
Old Jul 2, 2007 | 02:32 AM
2XVision's Avatar
Default Honda Carb info
Guys I need to know all the info you can give me on trike carbs.
Even so I`m sure I have most of it figured out, I`d like to know what the meaning of the pilot jet is and etc, I know what the main jet is and what it does. Also would like to know more about the idle jet and circuit. I`ve also seen slow jets and fast jets. All the info on how these carbs work and what the meaning of the parts is in them. Also need to know the difference it makes what notce the needle is set on and what it effects. I know the lower the needle the leaner the mixture, but would like to know why honda set them in certain places was it due for different elevations? All info on honda trike carbs, thanks much.
Old Jul 2, 2007 | 09:01 AM
Fulltiltrider's Avatar
Pilot jet is same as slow jet, idle jet. Main is the same as fast. Pilot jet is basically for idle and under .25 throttle. Your needle controls your fuel from .25 to .75. The main is the rest. The needle clip position varys for elevation and applicaion.(which motor its on)
toonces
Oct 16, 2019 12:11 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
Mikea1978
Jul 4, 2015 12:37 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
