Carb help
Old Jul 2, 2007 | 11:10 AM
guitarguy730's Avatar
Default Carb help
I have an 01' 400ex, and it's leaking A LOT of gas. I need to fix it soon, and most I've talked to have said it's probably a carb. problem. So I need any tips or help. Also if it is the carb should I rebuild or what would be the best option. And are there any good rebuild how to's because I've never done one. thanks alot
Old Jul 2, 2007 | 11:43 AM
coonhound130's Avatar
Default Carb help
A carb rebuild is very simple , the kit don't cost hardly anything , I paid $15 for mine from Honda , but if it is just leaking no need to rebuild , just do a gasket set , more than likely it is the float bowl gasket leaking ....
Old Jul 2, 2007 | 12:00 PM
Default Carb help
Thanks a lot man. So can I buy the rebuild kit/gasket set at a honda dealer or is there a place I can order it online?
Old Jul 2, 2007 | 03:18 PM
Default Carb help
Honda Dealership or just about anyplace online , including Ebay . But to be honest I would go with a Honda one cause the chepo aftermarket ones tend to have the wrong jets that will cause you to run lean , but if it runs fine just do the gaskets and don't worry bout the insodes .....
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
