My first build
Old Jul 3, 2007 | 01:39 AM
Cammer's Avatar
Default My first build
Well it came down to just putting a stock piston back in the pig after my "fatal flaw" experience. "see thread" and selling it or build er up [img]i/expressions/face-icon-small-smile.gif[/img]
By the title you can figure out what I did.
11.5 CP Piston, mild head porting, RWR 9 cams and TM 45 with Acc. pump activated. I am waiting for the shims which I should get tomorrow. With a little luck I will be testing/jetting it tomorrow. Wish me luck and what should my next mod be[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 3, 2007 | 01:46 AM
Cammer's Avatar
What kind of gains should I expect? BTW I already have ported the intake, oldman racing mods and full Alba exhaust.
Thanx
Old Jul 3, 2007 | 09:16 AM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
it should pull like a freight train
Old Jul 25, 2007 | 07:00 PM
Cammer's Avatar
You are correct, freight train it is! Mid range torque is AWESOME! I am thinking about the RWR CDI and a direct mount filter next. Are they worth the money?
Old Jul 26, 2007 | 12:45 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
YEP!
Old Jul 30, 2007 | 03:58 PM
derrick2v's Avatar
Im going to be rebuilding my DS soon, it just started to smoke a very little and noticed oil blowing out of the crank case breather. Im going with a 11.5:1 JE Piston(stock size). Would I be ok running a TM 45 carb, ported intake and ODP Endcap. I would like to run the stock cams, if thats possible? I will also get an aftermarket CDI Box? Any ideas on what box would be good to run with this setup?
Any info would be appreciated
Derrick
Old Jul 30, 2007 | 04:10 PM
Redstone's Avatar
For the price, I've always considered the RWR stage II one of the best values on the market.
Old Jul 30, 2007 | 04:13 PM
derrick2v's Avatar
All said and done whats a RWR stage 2 run???
Old Jul 30, 2007 | 04:36 PM
Goodsound's Avatar
Set a New OEM chassis 4 stroke national record on his OMW DS855 - 3.93 !
<div class="FTQUOTE"><begin quote>Originally posted by: Cammer
Well it came down to just putting a stock piston back in the pig after my "fatal flaw" experience. "see thread" and selling it or build er up [img][/img]
11.5 CP Piston, mild head porting, RWR 9 cams and TM 45 with Acc. pump activated. I am waiting for the shims which I should get tomorrow. With a little luck I will be testing/jetting it tomorrow. Wish me luck and what should my next mod be[img][/img]</end quote></div>
Old Jul 30, 2007 | 04:37 PM
Goodsound's Avatar
Shaving the flywheel, and a 520 chain set up are good inexpensive mods.
