19x8-8 tires
Old Jul 8, 2007 | 08:31 PM
G-man's Avatar
Default 19x8-8 tires
this is the tire size on the rear of my sons trx honda 90, and they are really hard to find size, so i was really confused on all the different sizes. I found a maxxis tire and the size is 18x10-8, will these fit, and can someone explain these sizes to me, i am guessing but is 18 the height,and10 the width, and 8 the size of the wheel diameter, and if this is true, will the 10 inch width to wide to seal on the 8 inch wheel, please help
Old Jul 12, 2007 | 01:23 AM
fosgate's Avatar
I have a 9.5 wide tire on an 8 inch rim an my kid's lt80. It looks fine! JL atv has a good tire selection for small quads.
Old Jul 22, 2007 | 10:08 AM
G-man's Avatar
well i got the 18x10 -8 tires for the trx and i had to space out the back wheels, modify the pipe mount, and then got a big hammer, and did a little hillbilly mechanic work, the problem when he went hard into a corner the tire would rub the pipe but now it is fine, and the tires really helped.
Old Jul 22, 2007 | 10:19 AM
billl2099's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: G-man
this is the tire size on the rear of my sons trx honda 90, and they are really hard to find size, so i was really confused on all the different sizes. I found a maxxis tire and the size is 18x10-8, will these fit, and can someone explain these sizes to me, i am guessing but is 18 the height,and10 the width, and 8 the size of the wheel diameter, and if this is true, will the 10 inch width to wide to seal on the 8 inch wheel, please help</end quote></div>
you're correct, 18 is the diameter, 10 the width and the 8 is the rim size
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
