Please help me with my jetting
Old Nov 8, 1999 | 06:33 PM
bigmanMH's Avatar
I have a bigred 200es and i need to no how to make it idle leaner and when i have it mid to full throttle make that richer. Is this possible or do you have to make it all richer or leaner. Thanks for your help and time.
Old Nov 8, 1999 | 08:01 PM
hot_shoe_cv's Avatar
you could try turning out the air screw 1/4 to 1/2 turn from normal and raising your jet needle one notch. By doing those adjustments it should lean out the mix off idle & raising the jet needle will fatten up the mix from 1/4 to 3/4 throttle. All Jetting is trial & error to a certain degree, depending on temp., alt. and phases of the moon.
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
Old Nov 9, 1999 | 12:03 AM
bigmanMH's Avatar
thanks for your reply by is there any need to change jetting.
Old Nov 9, 1999 | 01:02 PM
BigManMH,
Unless you have done some alterations to your air intake such as a filter upgrade or added an aftermarket pipe, and if the machine is running ok with no misses or flat spots I see no reason to change any jetting. In other words don't fix what isn't broken.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
