ds650 oil change?
Old Jul 14, 2007 | 07:01 PM
drbalazo's Avatar
Default ds650 oil change?
hi, I took out the drain plug (screw) from the bottom of the engine block and the oil filter but very little came out. What else should I do to get everything out so that i can put new oil in? any hel is appreciated, thanx.
Old Jul 14, 2007 | 07:10 PM
tombomb's Avatar
The oil reservior tank is located in the front of the bike on the frame . The black cylinder. It has two drain plugs on it . remove the right one ( if your facing the bike) and get ready for a slight mess as the oil runs down the frame. There should be a screen atatched to the plug and you need to clean this also.
Old Jul 14, 2007 | 07:22 PM
drbalazo's Avatar
thanx a lot
Old Jul 14, 2007 | 08:59 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Remove the left one on that tank first. A funnel under it to your drain pan is advisable. Once you've drained the crankcase and the left plug on the tank very little will come out of the right side mentioned. Clean that screen with carb cleaner, and the magnet on the case plug before reinstalling.
Lots of folks have put petcocks on that left plug so as to be able to contol the flow. do a search and you will find tons of info on this very topic.
Welcome to the forums.
Ace
Old Jul 15, 2007 | 12:00 AM
drbalazo's Avatar
thanx a lot guys. just completed the oil change and everything went smooth. thax again
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
