ds650 oil change?
ds650 oil change?
The oil reservior tank is located in the front of the bike on the frame . The black cylinder. It has two drain plugs on it . remove the right one ( if your facing the bike) and get ready for a slight mess as the oil runs down the frame. There should be a screen atatched to the plug and you need to clean this also.
ds650 oil change?
Remove the left one on that tank first. A funnel under it to your drain pan is advisable. Once you've drained the crankcase and the left plug on the tank very little will come out of the right side mentioned. Clean that screen with carb cleaner, and the magnet on the case plug before reinstalling.
Lots of folks have put petcocks on that left plug so as to be able to contol the flow. do a search and you will find tons of info on this very topic.
Welcome to the forums.
Ace
Ace
