lost spark 03 700
Hello.I went for a ride on our 03 700 2 weeks ago and after about a mile it started bogging then it would just idle and if you gave it throtle it would bog and die which it did.From the time it started to bog untill it wouldn't start was about 5 minutes.I got it to start yesterday but it stalled when I tried to give it throtle and then it would not fire.I thought a fuel problem,it was good to the carb so I pulled the carb apart and cleaned it but no go.I pulled the right plug wire off put a plug into it turned it over and got no spark,tried the left side and the same thing.Seems there might be intermitant spark becuase it did start but would not run above a low idle.Any ideas would be great---Thanks
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
vinrum
11
Aug 26, 2015 06:44 AM
