DS650 Squeaks!
Old Jul 26, 2007 | 09:32 AM
GForceAddict's Avatar
Default DS650 Squeaks!
I just bought a 2005 DS650X and love it but the darn suspension squeaks! I greased all the fittings with the Bombardier grease and it still squeaks.
Any ideas?
Thanks for your help...
Old Jul 26, 2007 | 10:17 AM
MRDS650's Avatar
Canadian and Proud of it !!!
If it is the rear suspension is is most likly the mount on the upper shock. What you need to do to fix it is jack up the bike and take the bolt out of the upper shock mount, pull the shock back a little until you can get the bushing out. You will see it kind of a bushing bearing style. Work some waterproof greese into in and put some more on the bolt. Put it all back together and the noise should be gone.
This usually lasts for a couple of years on my bike.
Old Jul 26, 2007 | 02:30 PM
FatHolly's Avatar
Do what MRDS650 says... be liberal with the grease, it won't hurt anything... if the greasing the rear doesn't do it (it's usually the upper rear though) then try the same technique on all your shock bushings.
MRDS650
Feb 22, 2026 11:26 AM
Ahtatu
Sep 28, 2015 12:14 PM
Canamaniac!
Sep 4, 2015 06:44 PM
ScoobyDFW
Jun 13, 2000 11:33 AM
