charging issue with a 1996 Scrambler 250
Old Jul 28, 2007 | 10:52 PM
chaos2984's Avatar
Default charging issue with a 1996 Scrambler 250
I have a 96 polaris scrambler 250. My lights stoped working one day and I never fixed it. and recently just got around to looking at the problem. So I take the battery out thinking it was the battery. But the batery was low on acid. So i filled it up and the batter accepts a charge nicely. But the battery doesnt recieve voltage from the magento at all. The voltage goes down on the battery. And i figured with my friends bike his lights work once he starts his lights work fine. i figure if Im putting out enough voltage to run the bike fine. it should let the lights work. but no lights work at all on the bike at all when its runing. i checked the circuit board and everything seems ok. but when i put power on the battery an charge it the lights work till the battery dies. Im not that good with magento systems. but im pretty good with electrical stuff. I just need something like a wiring diagram or what to test to find out whats bad on the bike.
Thanks
Dan
Old Jul 28, 2007 | 11:02 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
first thing to check is the recifer that controls the voltage to the battery. usually located in the front of the wheeler by the coil.
Old Jul 28, 2007 | 11:12 PM
chaos2984's Avatar
how do i test or find out if the rectifier is putting out votage or working properly
Old Jul 28, 2007 | 11:19 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the only thing you can really check is to see if its plugged in and not all corroded. you would a service manual to see if there is a ohms/or reistances.
Old Jul 28, 2007 | 11:28 PM
chaos2984's Avatar
ok thanx man ill have to check that out tomorrow.
scram5050
Aug 30, 2024 01:39 PM
GregM
Mar 6, 2018 06:53 AM
200es
Jul 19, 2015 04:50 PM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 13, 2015 05:11 PM
