big tires on stock 800
Old Jul 31, 2007 | 12:15 AM
polarisportsman800's Avatar
Default big tires on stock 800
how big can i go on a stock polaris 2006 800. im thinkin mud lites 27 inch. right now i have the 14inch rim, 26 inch bounty hunters on mine there not aggresive enough....plus my buddy on his 05 bombardier 800 kicks my *** in any kind of mud with his 30 xxl mud lites. could i fit the 30s with new springs and shocks?any imput on any 800 with big tires would be appreciated.
Old Jul 31, 2007 | 01:09 AM
ANVIL1988's Avatar
no you will need a clutch kit at least im sure of it
Yamaha 4 life
Old Jul 31, 2007 | 02:09 AM
im new to the quadin game w,...why a clutch kit for new tires? does a clutch kit add more performance in the low end?....to get the tires spinnin?
Old Jul 31, 2007 | 07:44 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you will need a lift kit and a clutch kit if you go w/ anything over 27". i have xtr's 27" on my 800 and i did add a primary spring, but w/ anything bigger it takes more clutching to keep up the power low end when turning the bigger tires. if you stay w/ the 27" you wont need a lift kit and most likely can get by w/ stock clutching. no matter what, you wont stay w/ him bombie w/ 30" tires. it has more power to begin w/ anyways. just a thought
Old Jul 31, 2007 | 12:10 PM
yeh his bombie has a TRUE 800 CC motor and 689 lbs compared to my 760 cc and 777 lbs....thats a big difference. well thanks for the help .did some reaserch last night , probley go with the 27 mud lites and a clutch kit from outlaw, all ready fell under powerd when i first hit the mud...
Old Jul 31, 2007 | 12:27 PM
duffus's Avatar
already felt underpowered?
One of the guys I ride with has 28" on his 700efi (they scrub just a little), but even without a clutch kit, he doesn't have a problem turning the tires. Remember to use LOW in the mud-- high gear is for general trail riding.
Remember... when he's replacing his chassis because he bent it on a rock, you'll still be riding. Look at how his chassis is make-- very clever, but the skidplate is the frame. Once it is bent around some the bombie will get clutch misalignment and suspension torques because of a bent frame.
Old Jul 31, 2007 | 02:46 PM
kas379's Avatar
Please tell me you don't really believe a few dings, dents and scratches on the bottom of a Can Am's center spar has an effect on the torque or handling. What planet are people from that they feel it's necessary to spread stupid crap like that. A skid plate does the same thing for a Can Am it does for any other make, which is prevents the the vital components from getting dings and dents. If you decide to drive into a car, a tree, or a stone wall, the frame might buckle or twist similar to the damage that would happen to anything else with wheels. Then you might notice a problem. Think before you repeat things you heard other idiots say some where else!
Old Jul 31, 2007 | 03:36 PM
800, underpowered? I've gone through some nasty stuff with my 500s and as long as I leave it in low they've got through everything so far. Use low for anything under 10mph and it should have plenty of tourque.
Old Jul 31, 2007 | 04:37 PM
i may have miss wrote the under power thing... it has loads of power . it hit a mud pit and there was a log hiddin underneeth and i got hung up , when i let of the throtle to go in revers and back to low it just seemd a little sluggish gettin the tires to spin again(from 1150 to mabey 2500 rpm) thats where my whole under power thing came in . i do have the 26/10/14 o front and 26/ 12/ 14 on back...the bounty hunters.. wondering if that might be takin a little torque away.
Has anybody put 27 mudlites on the stock rims? clutch spings are cheap enough so i got no problem with buyin one .
Now for the bombardier.. my buddy has rolled his down a 10 foot bank.........$5000 damage , needed a new frame and he got thedealer to fix it . hes still finding loose nuts and bolts , but im not dissin the machines i think there great ... it make me jellous evey now and then , but mines got the comfort , the smooth ride ,exellent handling , smooth power and lots of it . his is just bigger , lighter and more top end , that could be due to his 30s hes got.
Thanks to u all for the help and info , happy ridin [img]i/expressions/face-icon-small-smile.gif[/img]
STLyamwar
Jul 25, 2020 04:44 AM
Ean
Aug 28, 2015 09:39 AM
XxS0ccerstarxX
Aug 27, 2015 02:31 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
