i need help
Old Aug 1, 2007 | 02:12 PM
dafourwheelinvidman's Avatar
Default i need help
ok honda recon i used the neutral gas and shift method for wheelies i fear ruining my qaud so i need suggestions here what u need to know has front and back rack no wheelie bar and has 5 gears all help is mcuh appreciated
Old Aug 1, 2007 | 07:35 PM
mykool61679's Avatar
Default i need help
you will eventually grind/chip/strip the gears in it! i would chill out on it!!!
Old Aug 3, 2007 | 12:29 AM
mudman420's Avatar
Default i need help
put your feet in the back rack and gun it but make sure you pull up and thats it
o3 kx 250
07kx100
Old Aug 8, 2007 | 02:19 PM
reeder05's Avatar
Default i need help
nuetral drops are never good!!! just move your weight to the back, pull back and giver er gas. if that does'nt work, give up!!! dont do those nuetral drops. your bound to hurt your honda up bad.
Old Aug 8, 2007 | 04:59 PM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
Default i need help
First thing is your recon is not a Wheelie machine! It's not even a sport quad.
Are you even old enough to ride a quad?
