Scrambler Swing Arm Problems
Anyone have problems with the swingarm bushings lasting? Seems like every time I go ride I have to use nearly an entire tube of grease. The bushings just don't last long. Any help is greatly appreciated!
Welcome to the forums, Crashxx. [img]i/expressions/face-icon-small-smile.gif[/img]
My nephew has had a problem with the swing arm bolt. Loosens up and gives the whole rear end about 1/2 of play.
He's the lazy type, so he hasn't looked at the bushings, but I would think it's been tough on them as well.
Are you replacing them with factory bushings, or have you tried any after market brands?
Yea, I replace them with an after market brand that my local shop says is the best around. I'd like to find an after market swing arm that a guy could use sealed bearings in instead of the bushings. Hopefully someone will have a solution on the forums.
most of the time it isnt the bushing itself but the brass bolts and spacer that wear.Check them if they are bad it is a Stealership item. replace the bushing with Pivot Works bushing.
1000gade
Jul 16, 2015 10:48 AM
