Scrambler Swing Arm Problems
Old Aug 3, 2007 | 01:23 PM
crashxx's Avatar
Default Scrambler Swing Arm Problems
Anyone have problems with the swingarm bushings lasting? Seems like every time I go ride I have to use nearly an entire tube of grease. The bushings just don't last long. Any help is greatly appreciated!
Old Aug 3, 2007 | 01:34 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums, Crashxx. [img]i/expressions/face-icon-small-smile.gif[/img]
My nephew has had a problem with the swing arm bolt. Loosens up and gives the whole rear end about 1/2 of play.
He's the lazy type, so he hasn't looked at the bushings, but I would think it's been tough on them as well.
Are you replacing them with factory bushings, or have you tried any after market brands?
Old Aug 3, 2007 | 02:26 PM
crashxx's Avatar
Yea, I replace them with an after market brand that my local shop says is the best around. I'd like to find an after market swing arm that a guy could use sealed bearings in instead of the bushings. Hopefully someone will have a solution on the forums.
Old Aug 3, 2007 | 05:05 PM
03scrambler500's Avatar
If you went to your local machine shop you could have them make brass bushings then they would last alot longer. It might cost you more but they way outlast the plastic ones.
Old Aug 3, 2007 | 06:32 PM
ftwflh's Avatar
most of the time it isnt the bushing itself but the brass bolts and spacer that wear.Check them if they are bad it is a Stealership item. replace the bushing with Pivot Works bushing.
Old Aug 4, 2007 | 10:57 AM
crashxx's Avatar
Well, I thank you all for your input. However, I got fed up last night and went and bought the Can-Am Renegade 800. Hopefully I'll have better luck whith this one.
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 12:11 PM
maxjung
Jul 13, 2015 05:11 PM
