250X Sluggish Performance
Old Jan 1, 2001 | 04:27 PM
GR8T250R's Avatar
My friend has an '87 250X w/ these mods.- Wiseco pro-lite[.20 over],ported head,heavy duty valves/springs,W.B. [race?]cam,Mikuni flatslide[mm?],K&N filter,DG Chromepower ex.[full],Stock gearing,stock tires.Jetting is very close. This machine does not run as well as I think it should(perf.).I have a 350x (stock) and I don't believe the 250 is even close,even with these mods. We have not actually raced them, but I have ridden both.Does anyone have any Ideas on getting more power from this setup? No more money to spend! THANKS!
Old Jan 1, 2001 | 04:33 PM
GR8T250R's Avatar
P.S. Also has ROOST BOOST ignition! Stock CDI box. Holes in Airbox lid. We have run w/all pipe discs and none. Not much diff. Jetted to run all.
Old Jan 1, 2001 | 05:58 PM
letitsnow's Avatar
Did he just put the cam in, or has it been used for a while?
Old Jan 1, 2001 | 06:14 PM
GR8T250R's Avatar
The cam has been in for a while. I will guess 20 hrs. on all mods.
Old Jan 1, 2001 | 06:28 PM
letitsnow's Avatar
I don't think that with the mods you have listed, the 250x will be close to the 350x in power. If I remember right, a stock 250x puts out about 12hp at the rear wheels. The cam, piston and pipe maybe add 5-6 real world hp. The 350x puts out about 22hp or more in stock form. If you still think there is something wrong with the 250x maybe start with a compression check(might have a ring that was bent or something), check to make sure that the cam timing marks are aligned(could be a tooth off). This is probably a dumb idea, but, make sure the clutch isn't slipping. And last but not least, check the valve clearance(if this was set wrong, it could be holding a valve open slightly when it shouldn't be).
Good luck!
Old Jan 1, 2001 | 06:54 PM
94DGblaster's Avatar
12hp?
they put out about 15 or 16 stock...with all those mods to me he should be putting out about in the mid to low 20s.
5 or 6 for piston cam and pipe, plus porting and a vavle job..thats another 2 or 3...
Valder
Nov 28, 2020 07:38 AM
Customer Service #1
May 15, 2020 08:46 AM
Sep 30, 2015 01:37 AM
jankerstien
Sep 21, 2015 03:09 AM
