DS650 axle?
Old Aug 3, 2007 | 08:20 PM
01ds650's Avatar
Default DS650 axle?
Last time we were jumping cars at our show my friend on his 2001 DS came down short and landed on his truck. It bent the axle on the DS. The cheapest I've found so far is a durablue thru Rocky Mountain ATV for $309 shipped. Anyone know a better price?
If anyone has a used BUT STRAIGHT & NEVER REPAIRED axle that would work too. We dont want to use a repaired one because of the nature of our jumps.
Thanks guys
ps> Any tips for axle removal and/or install?
Old Aug 4, 2007 | 11:37 AM
burk1231's Avatar
Default DS650 axle?
u might want to check on ebay.i found 1 for a o4 there which was a durablue for 95 dollars shipped.i have a o3 which i had to do some machining to make it work but it seems fine now.if u have a o4 or newer you have to shave your brake hub down a little with a grinder or haxsaw takes about 5 mins at most..i see you have a o1 so some machining will be necessary or you need to get the hubs,sprocket hub and brake hub off a 04 or newer .hope this helps ya.
Old Aug 6, 2007 | 04:22 PM
ERBEDS650's Avatar
Default DS650 axle?
Olds check you PMs
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
