Jumping out of second
Old Aug 5, 2007 | 01:28 PM
hawkeye300's Avatar
Default Jumping out of second
What would make my Banshee jump out of 2nd on hard acceleration ( climbing ), won't do it under normal condition's.
Old Aug 5, 2007 | 08:23 PM
beaty's Avatar
umm does it just act like its in neurtal when it happens
Old Aug 5, 2007 | 09:00 PM
kawiking's Avatar
sounds like maybe your clutch is slipping.......
Old Aug 5, 2007 | 09:32 PM
hawkeye300's Avatar
No, it goes directly to nuetral, all other gears are fine. I had it out earlier around home and I could not get it to do it. Maybe the shift fork is wearing?
Old Aug 5, 2007 | 09:45 PM
kawiking's Avatar
DOES YOUR SHIFTER FEEL SLOPPY ?? ITS HARD TO TEAR UP A BANSHEE TRANNY....
Old Aug 5, 2007 | 11:51 PM
beaty's Avatar
yeah i havnt figured it out but that happens on my banshee every once in a while but it only happens when im going up hill running high rs and then i click the lever down and it goes back to the gear i shifted out of
Old Aug 6, 2007 | 12:09 AM
kawiking's Avatar
go to banshee hq.com and ask... id like to know what it could be also.
Old Aug 6, 2007 | 07:30 PM
rruser's Avatar
2nd gear is almost always the first to go out on higher HP engines. Warn gear dogs will do that or it could also be a warn thrust washer or shift fork. Or maybe its the shift drum. The only way to really tell is to open it up and check it out. The Banshee/RZ motors were not known for having bad transmissions but Yamaha XS750s, XS850s, and XS1100s all blew out 2nd gear due to warn out gear dogs. The gear worked perfect after the dog teeth were cleaned up with a file.
Hack714
Sep 26, 2015 08:11 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
black_thunder
Sep 22, 2015 07:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
