Front axle replacement
Old Aug 13, 2007 | 09:08 AM
my700's Avatar
Default Front axle replacement
The other night I broke the front axle on the right side on my '05 SP 700 and now I have th front gearcase apart but how in the he!! do you get the axle out of the output hub. Any help would be great and pics would be even better.
Old Aug 13, 2007 | 10:24 AM
TNT1007's Avatar
Hey I am in the same boat. I just need to replace the boot. I am getting ready to go out and give it another try. If I figure it out I will let you know.
Old Aug 13, 2007 | 11:11 AM
TNT1007's Avatar
ok I just got it. the ball joint that connects the strut mounting to the a-arm has a nut and cotter pin at the bottom, take those off. Then grab a hammer and hit the a- arms until it falls off the strut. Then you can get it out.
Old Aug 13, 2007 | 11:19 AM
my700's Avatar
I have the axle out of the strut now i need to know how to get it out fo the gearcase. I have the gearcase apart but i cant get the axle out.
Old Aug 13, 2007 | 02:42 PM
BigCountryUSA's Avatar
I just had my frnt diff out for a roll cage issue - the shaft will come out of the front diff w/o taking the housing apart. I used a large screwdriver and carefully applied some "english" between the diff housing and the inner boot area. There is a circlip type fastener on the end of the shaft that will self-compress and it should pop out.
Old Aug 13, 2007 | 02:56 PM
my700's Avatar
I did more research and thats what i found out now , after i took my diff apart. My computer has been down at home so i had to come to work to screw off and find out what im doing. Ill go home and try to get it all back together. Thanks
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
rcappie4
Jun 21, 2015 07:33 PM
mitchetr
Technical and How-To Articles
Jun 10, 2015 08:36 AM
rcappie4
Jun 7, 2015 02:53 PM
cornermike
May 27, 2015 10:04 PM
