Foreman 450ES Useing alot of gas
Old Aug 17, 2007 | 12:49 PM
a381221's Avatar
Default Foreman 450ES Useing alot of gas
I put an air fuel meter on it and it would get down to 11.5X:1 under a load. is there any way to lean this quad out?
Also its ticking a little bit does anyone the Specs on the Adjustments?
Old Aug 18, 2007 | 07:12 AM
HondaTechnician's Avatar
While Honda doesnt give the exact ratio of air/fuel, My memories says it should be at about 14:1. Does it run well? Is the spark plug blackened? Is the air filter clean?
If you are still thinking it is to rich, you can change the main jet, install a new slide needle or adjust the current needle if its ok. Get a high flow air filter, however with a high flow air filter you also get more dirt.
Old Aug 18, 2007 | 09:34 PM
cluby's Avatar
What's your gas milage and or how many hours can you run it before filling up. Far as specs .006" on intake and exhaust. Does it run good?
Old Aug 19, 2007 | 06:51 PM
old's Avatar
old
Make sure the choke cable has slack in it and is not holding it open just a tad.
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
neilbedwell
Nov 10, 2018 11:02 AM
neilbedwell
May 31, 2015 11:11 AM
clayman
Jan 25, 2000 05:57 PM
