hard to get in reverse
Old Aug 18, 2007 | 10:27 AM
brownweiser's Avatar
Default hard to get in reverse
i have a 2002 sportsman 500 it is a little hard to get in reverse but it will go in after awhile, any ideas?
also what oil should i use when doing a oil change?
thanks
Old Aug 18, 2007 | 10:51 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
does it grind or is the linkage just gummed up? use 0-40 fully synethic.
Old Aug 18, 2007 | 10:58 AM
it will grind when going it forward but thats normal. when trying to get it in reverse it wont let you hard to push in. takes some time then it goes
thanks
Old Aug 18, 2007 | 01:05 PM
south009's Avatar
ha 97 500 sporty i had same trouble had to adjust linkage .you have to do both uhook from shifter locking nut on top outside one is reveres threads bottom standerd. use to wrenches. to unlock rods they will break.been ther done that.a couple of turns on rod will do it. hope that helps you ......
Old Aug 18, 2007 | 01:17 PM
south009's Avatar
me again forgot to tell you take side cover off look at cams on top of trans put in reverse see what way cam goes for reverse adjust rod to make cam go farther....
Old Aug 18, 2007 | 01:41 PM
thanks guys i will give it a go
Steeldon
Sep 9, 2015 09:38 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
