Wolverine Reverse Limiter
Old Aug 20, 2007 | 11:25 PM
suthrnstyl's Avatar
Default Wolverine Reverse Limiter
Has anyone bypassed the limiter on an '06-'07 wolverine 450 yet? If so how did you do it? I have searched the web and these forums and haven't found any info pertaining specifically to the wolverine. Thanks in advance.
Old Aug 21, 2007 | 03:12 PM
yotatrailrunner's Avatar
Might try removing the wire from the reverse switch and see if that works.
Old Aug 21, 2007 | 04:22 PM
hondabuster's Avatar
Do a search on the kodiak or grizzly bypass. Should be the same fix, and same color wires.
Old Aug 21, 2007 | 07:19 PM
suthrnstyl's Avatar
Just did it the way the link said for a grizzly and it worked. Thanks for the help.
Old Aug 22, 2007 | 10:44 AM
ctateusa1's Avatar
Hey can you post the link for the grizz bypass so I can find it as well.
Old Aug 22, 2007 | 12:48 PM
suthrnstyl's Avatar
http://quads.ca/tech_kodiak_re...rev_limiter_bypass.htm
Just realized this is for the Kodiak, but from what I understand it's the same.
Old Aug 22, 2007 | 01:41 PM
You can also splice it into the over ride button, on kodiaks, so that the override does both over rides...low lock and reverse.
Old Aug 22, 2007 | 02:48 PM
ctateusa1's Avatar
unfortunatly the wolverine does not have a low lock
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
